Chat - ak: Your IP address is BLOCKED by our DNS blacklist !
Vsetko ohladom klubu, oznamy, pripomienky a pod.
Príspevok od užívateľa Erin01_47 » 06 Feb 2012, 22:12
Viacerim sa stava ze ak sa pokusa pripojit na chat nepripoji ich :(
Pokial dostanete takuto info:
[21:42] == +++ Your IP address (VASA IP ADRESA, resp. VASHO POSKYTOVATELA) is BLOCKED by our DNS blacklist!
[21:42] == +++ To limit abuse, you cannot use this webchat client through your browser. You can connect to QuakeNet using a normal IRC client in the mean time, however we strongly advise you check your PC or network for problems.
[21:42] == +++ This is a problem with your IP address and/or computer, this is not a problem with QuakeNet, please fix it without contacting QuakeNet.
[21:42] == +++ Alternatively, if you log in you can bypass this block (use the "log in to Q" button).
[21:42] == +++ Oblivion awaits...
[21:42] == Disconnected from server:
Je to preto ze tato IP adresa je na zoznamoch blacklistov
/dovody su zvacsa tie ze z rozsahu kde sa ip adresa nachadza je posielany spam
a preto su tieto adresy AUTOMATICKY zaradene do blacklistov priamo servermi.
Odblokovanie moze riesit len Vas poskytovatel
/zdlhave, casto neuspesne pokial ma na sieti zavireny PC, server a ten dalej posiela spam/
Overit si to mozete napr. na stranke: http://www.mxtoolbox.com/blacklists.aspx
/treba napisat svoju ip adresu ktora je uvedena v casti == +++ Your IP address ( )
V takom pripade odporucam pouzit nasledovnu moznost na pripojenie k chat-u.
/niektorym uzivatelom to pomohlo/
Firefox + rozsirenie chatzilla
https://addons.mozilla.org/sk/firefox/addon/chatzilla/
po restarte naklikat : Firefoxu > Nastroje > chatzilla > chatzila > preferences
a)
vypisat NICKNAME /napiste sem nick aky mate na fore/ priklad: ferkoleon
vypisat NICKNAME (away) /Vas nick_aw/ priklad: ferkoleon_aw
b)
v zalozke startup v casti location kliknut na add a vlozit
irc://quakenet/seatclub.sk" onclick="window.open(this.href);return false;
potom apply, ok zavriet chatzillu a opat spustit.
Pokial budu otazky napiste mi PM.
Skusim doplnit obrazky, pripadne postup dalej upravit.
Vo velkom okne vpravo vidite hlavnu cast "sklo" kde je text co kto pise na chate.
Vlavo vidite prihlasenych uzivatelov.
Na ostatne pridete pouzivanim :)
Návrat na "SEAT CLUB Slovakia"
